310e case dozer
No it isn't. 188 is longer, the radiator is different and a few other things are different
(quoted from post at 18:02:36 03/02/17) No it isn't. 188 is longer, the radiator is different and a few other things are different
Thank you for responce.
Is the bellhousing the same? The rest i can work with
Yes the bell housing is the same. I think they used a shorter driveshaft for the diesel but I don't have a 310C book to see if it even came with a diesel.
I'm not sure on the radiator , but if you look, I bet you will find that the frame rails are already drilled in the front to mount the 188 in place. The 188 is 1-3/8" longer.
Loren
