I have a 310 and it needs wheels on back. The lug holes are wollered out bad. Is there a way to fix them myself or do I need wheels?
Do you have the one piece wheels with the rims welded to the center or the two piece where the rim bolts to the center? Lee
Seems like some had 6 holes and others had 8. Either way check with Miller Tire in Ohio for the availablility of reinforcing rings that you would weld right onto the rim. Might need longer bolts.
The 310 round nose wheel has 6 lugs. The 310B was 6 lug until changed to 8 lug at s/n 6128060.
Pic is '56 310 round nose wheel.
Joe
