new year project/ eagle hitch
CZ
Found enough time to get a little work done on the project. Made up a bracket to mount what will be my hydraulic tank. Then relocated the oil filter and plumbed it in. Now there will be room for the hydraulic filter and the pump, when its mounted between the governor and magneto which moves aft as a result. Have decided to hard pipe the whole system, so now its time to go buy some tubing, and get out the old Imperial-Eastman benders.
Actually, get that all fabbed up and painted and you will have to start putting your skills towards building some Eagle Hitch implements for it!
Soon as I get the penetrators for the inlet and outlet fittings welded or brazed in, it gets a coat of the old Flambeau Red! I also have a filler/strainer to put in the top and a fluid level gauge, which will screw into the existing penetrator on the side, you can see in the pictures.
You read my mind, I have a couple of ideas floating around in my head! I think I'll take a break before I do that though.
