Case 85XT Axle Replacement Questions
tradbeau
New User
The axle on my early model Case 85XT is broken and I'm having a hard time finding a replacement. The newer version axle is plentiful. Does anyone know if you can retrofit the early models to use the newer axle? The older ones have a dust seal and spacer on the inside and the newer ones did not.
Old: http://www.colemanequip.com/Case-85...AND-JAF0297642-JAF0298061-1SPV/?#partdiagrams
New: http://www.colemanequip.com/Case-85...n-4X/AXLE-ASSY-JAF0298062-BcmC/?#partdiagrams
I ended up with the newer axle because an online vendor had it listed wrong. I'm working on sending it back.
Thanks,
Tradbeau
Anyone? How about putting a whole new style axle assembly on? The later model axle assemblies are easier to find as well. The newer axles are so close in spec.
I have a really good axle and hub assembly for an 85xt. There were 3 different axles found on your machine. Get the number off the end of your axel (hub face) and let me know.
