I got the d case home one issue
Got the d home the other day one problem I saw right away is the PTO lever for the live PTO is stuck up in the on position I removed the pin from the rod back where it goes into the PTO housing it moves just fine. So my next idea is to take the plate off the top and take a small pry bar to it I don't want to break anything anyone else had this happen? Wanted to ask before I went in there.
Thanks loren
Pics I hope
Third and forth times the charm lol
The guy beside the d is my buddy Sam
And the guy on the seat is my great
uncle roger said he ain't been on the
seat of a d in 30 years so he took
her for a spin.
Loren,
Very nice late model D you have. More than likely you can free the linkage on the over center PTO clutch using a couple big screwdrivers as levers. With the cover off you should be able to see if there is anything wrong in there that might be causing your trouble. Good Luck. Don
Looks like a nice solid farm tractor Loren, hope you enjoy your "D" as much as I enjoy my "DC3"s. Thanks for posting
