Case 2590 3pt. Hitch Problem
srooney
New User
My 3pt. Hitch has trouble going up and down without assistance. I have to put my weight on it to make it go down and pull up to help it go up. After I did this for a few minutes it worked good all day. Next day it's having trouble again. Any suggestions to fix this?
I will throw out a few suggestions, I do not recall a problem like the one you are having so this is a general suggestion.. First make sure both hitch and sensing cables
are attached and operating. If all is well there take the spool cover off the front of the valve and have someone move the hitch control lever back and forth, (engine
off) the spool should be going in and out. If that is OK remove hitch valve and clean and reseal it. Do not mess with the adjusting screw on the lowering spool. Also the
trans oil sometimes needs to be drained before valve removal. A CASE manual will show proper procedure of valve removal and installation. Rod.
