Eagle hitch drawbar
mschwartz
Hello Looking for the measurements to build an eagle hitch drawbar. Have seen pictures posted but cannot find the one with the measurements. Looks very handy for moving equipment around. Thanks, Mike
John Saeli sells them. Great quality and exact copy of the original.
Shipped right to your door. Might be worth the inquiry.
Here is a pic of mine. It works great for skidding logs and for moving trailers and equip as you suggest. As said, John has or had some made up.
It wouldn't be too difficult to fab up one using a common 3pt. crossbar and some suitable angle iron.
Loren
VAC, SC, or DC, feel confident that I can build one but unsure from pictures how heavy the iron actually is to start with?
On the Case built 3pt drawbars the bar itself is made from a 2-1/4" solid bar with holes drilled and taped into the ends for 3/4" cap screws. If you decide to make one utilizing a common drilled cross bar. make the uprite angles from at least 3" x 3/8" thick stock, and fab the uprites to bolt to the the cross drawbar so it lays flat, not vertical or you will bend it.
Loren
Thanks that is a little heavier than I thought from looking at pictures, good to know. Could you measure the length of the round cross bar for me when you get a chance, thanks, Mike
