700KK
1370ROD Thanks for your advice last week,I did buy it Saturday,drove it home Sunday .First thing I have to fix is the right brake ,no right brake.Then a lot cleaning ,7 years sitting its real dirty.
Congrats on being the proud new owner. As for the brake the easiest thing is to try bleeding them, if no luck doing that check the little link rod that connects the pedal to valve. There is a plastic joint that can break, by checking the rod tightness with the operating brake you can normally tell a difference. When up in place you cannot see the problem without disconnecting the rod from pedal. Rod.
