Part number check please.....
Straw Boss
Can anyone verify if the drawbar on a late 770 is a breed of it's own, not shared with an 870 or any other 70 series?
In my book, the drawbar part number is A64193 for serial number break 8693001 and after.
I don't have an 870 parts book or any other books to check it against. Thanks in advance.
Cross-ref the p/n's and ran them on the CaseIH parts site. #1 A60410 was the early 770 drawbar, the p/n was later changed to 135276. #2 A64193 is the drawbar p/n you provided. It was later changed to 135276 also. That doesn't mean they are identical possibly that Case just considers them suitable substitute. They may have just run out of the original bar and didn't have enough demand to manufacturer more. #3 A60410 on the 830 is the same p/n as the early 770. There are other drawbars of 830 but they don't cross-ref any p/n above. I did a quick check of 930, different p/n's didn't have time to cross-ref. Can do it later if you need. Get a hold of John Saeli, ask him to check my nrs. He'll do it for a beer if Chris will let him have it.
1. Location: (770) - CASE AGRI-KING TRACTOR (S/N 8675001 & AFTER) (1/70-12/72) > (298) - DRAWBAR, W/HITCH, USED PRIOR TO TRACTOR S/N 8693001
A60410 DRAWBAR - standard p/n changed to 135276
2. Location: (770) - CASE AGRI-KING TRACTOR (S/N 8675001 & AFTER) (1/70-12/72) > (299A) - DRAWBAR, W/HITCH, 1ST USED TRACTOR S/N 8693001
A64193 DRAWBAR - standard p/n changed to 135276
3. Location: (870) - CASE AGRI-KING TRACTOR (S/N 8675001 & AFTER) (1/70-12/74) > (299A) - DRAWBAR, WITH HITCH, USED PRIOR TO TRACTOR SERIAL NUMBER 8693001
In the text I wrote 830 instead 870 and 930 instead 970. I must have 30 on the brain, too bad I don't drink or I would have John's beer. I am going to post a corrected copy. Maybe Kim will come along and delete the 1st one.
Cross-ref the p/n's and ran them on the CaseIH parts site. #1 A60410 was the early 770 drawbar, the p/n was later changed to 135276. #2 A64193 is the drawbar p/n you provided. It was later changed to 135276 also. That doesn't mean they are identical possibly that Case just considers them suitable substitute. They may have just run out of the original bar and didn't have enough demand to manufacturer more. #3 A60410 on the 870 is the same p/n as the early 770. There are other drawbars for 870 but they don't cross-ref any p/n above. I did a quick check of 970, different p/n's didn't have time to cross-ref. Can do it later if you need. Get a hold of John Saeli, ask him to check my nrs. He'll do it for a beer if Chris will let him have it.
