Don if you were close by I would give you the one that I made. I had a tiny dent in my 870 grill & I got to looking & thinking & decided I could make a straightener out of some wood 2x4s. I cut them fairly close with my saw & then I took my hand held planner & fine tuned them to the point where these fit perfectly in the unbent part of the grill & then put them on top & bottom & laid it on a hard surface & started tapping on the top 2x4s & then flipped it over & tapped on the others & it turned out perfect.
I used to use a 1/2" bolt about 5" long and welded another bolt 90? to the 1st, making a T. And block of wood with a groove in it for the damaged grille portion to set in. Cheap and easy.
