700KK
I am looking at a low houred 1570 coming up for sale this weekend. It hasn't been ran in 7 years and i would like to know if there is any problems i should look for. I haven't had time to look at it yet but it is supposed to run and shift good. Is there any concerns with it sitting for so long? Thanks.
Only concerns are the normal old degraded fuel and check trans and engine oils for water contamination and proper coolant level. I am sure you know if in fact you do purchase the tractor that all the fluids and filters should be changed. Rod.
I was also concerned if some of the seals could be dried out and start leaking when put back in use again.
Some might seep a little, but for the most part after a bit of use if they were OK before storage they are normally OK after.
