case 311 oils
Oil chart is from 300 series tractors service manual. Steering gear box takes a little more than a quart of SAE 140 gear oil.
Modern oils are much better than when your tractor was built, there were no high detergent or multi grade oils. In my 300's I use straight SAE 30 in the engine since I am in a moderate climate and also an old geezer. Many here use SAE 10w30 which may be better pending your climate.
I use a general purpose hydraulic oil in the torque tube since it has a common spur hydraulic pump and there is nothing special in the hydraulic system that requires a more expensive oil. Main thing is low viscosity and anti-foaming.
You have one of the best little tractor ever built. Welcome to the Case forum, lots of help available here. No question too dumb. We all started the same way.
Joe
I have a 311 gas round nose. 10W30 in the engine and the NAPA equivalent of HYTRAN for the transmission/hydraulics. Lot of inprovments in lubricating oils since those old tractors were built, have to think that if modern lubricants were available then, that is what would have been recommended.
