1370 and Brown tree cutter
111
This is what I do for extra money, I bought this brown tree cutter a few years ago and clear lots with it, works great behind the 1370. It cuts 6 inch trees no problem and will do 8. In total I have about 30 lots to do now ranging from about 1/2 an acre to 30-35 acres, the 1370 clears the lots and the 1570 or the 930 with the rhino chopper cuts the weeds and grass.
Ben
What is a "brown tree cutter"? Is it a heavy duty bush hog? It looks like the deck of one. I've so many acres of neglected pasture land that's grown into Willow, Dog Wood, prickly ash etc, I'm always looking for a better way to work with the stuff........
Yes it's very heavy duty, the gearbox is about 16 inches in diameter, has a 6 ft wide 1 inch thick blade bar with 4 short blades 3/4 thick, mine is the same as these but has a bar to push trees back before it cuts them to stop trees from falling back on tractor, I put a screen behind seat to stop from getting hit with debris, it will throw huge chunks up at the driver. I bought mine used and paid $4000.00 but worth every penny, here are some pics and a YouTube video, watch video it shows what they are capable of, you knock down trees then just run them over, I mostly back over with the 1370
Ben
Untitled URL Link
That thig looks like it works good , but I bet it's tough on a tractor , especially the tires . Do you get many punctures ? We have so many buck thorns , Amish style wheels would be a must if you wanted to work all day without a flat.
Knock on wood no flats yet, I have been through lots of thorn trees, I keep chopper low as possible and run low air pressure if I have a problem I might foam fill the tires, but it's been 3 years using it now and no flats yet.
Ben
