I am currently restoring a Case SC. The hand clutch lever is really sloppy. It doesn't look like it was ever greased. What is a good way to fix that? I recently did a B John Deere and you could buy a
replacement pin and then just bore out the handle hole. That worked really well. The SC however has a special bolt that is one of the bolts that holds the axle housing on. I thought about getting the next
size shaft, cut off the worn out part, and weld the new shaft on. Then bore out the lever bore. Anyone have some better solutions?
