Information needed on CASE 400 lbs weights
IH1586
New User
Hello, my first time posting on this site. I bought some CASE 400 lbs rear wheel weights to mount on the CASE heavy cast centers. I found out later (after I bought them) that you mount them on the inside of the cast centers. Has anyone ever mount them on the outside of the cast centers. This would be on a 2590 or 3594 type tractor. These cast centers have the 4 tabs which look likes the weight would inside of. I was told they may not fit flush to cast center therefore the reason for mounting on the inside. Any help appreciated as I have search everywhere and have found nothing. If possible photos would help. The weight is # 15 in the image and the cast center is #12
May not be much help but we have a set on the outside of the "lighter" cast centers on a 3294. Put them on with all thread about 10 years ago when we put the loader on and haven't had an issue. Wouldn't say they are formed to fit but it works.
Hello LJKCK! Thanks for responding. At least this gives me some hope that I can mount mine on the outside as well. These weights are (hopefully) going on a CIH-7250 which has the CASE heavy cast center. It looks like it should work but I am going by looks and guessing. Do you have any photos of your 3294 weights that you can send me? If possible maybe we can talk by phone? One of my concerns is, IF the weights don't fit well, with the road speed of this tractor would that cause the weights and tractor to be off balanced? I wonder if I put a set of the 140 lbs on first and then the 400 lbs weights would that arrangement work? Any help appreciated.
Thanks
IH1586
