2470 PTO Question
1370rod
The PTO brake on my 2470 does not operate. I have never seen or had the clutch unit on a 4wd off. Wondering if it is much of a job. PTO pulls strong but the brake seem like there is nothing there. Looks to me like a skinny guy would have to work from below. Rod.
I lay on my belly on a creeper resting over the back end. After hyd lines are cleared away, lay a pipe across trans and rear of tractor and loop a chain around unit to be removed and slide back.Hope your main drive brg opposite RPS carrier brg is OK or your in for a nasty job.
