case 990 buy or leave
plowboy555
New User
I'm looking at a Case 990. i don't know when the last time it was ran and neither does the owner of it. its got the remotes and power steering and all still hooked up the wiring lookes good everywhere. But I'm at it to get running and use it for food plots and bush hogging and stuff like that. Any advice is much appreciated.
Can you check if the motor still turns? Post some photos of the tractor? Tell us how much he wants for it? From the info supplied so far, I'd offer him $500 for it. If you are not already familiar with David Browns, maybe you should pass. This tractor was made in England. Even if you can get it running, the hydraulic system is frequently problematic, and can be frustrating to troubleshoot. If everything works good, its a great tractor though! I own four 990s. Give us some more detail and post some photos!
(quoted from post at 17:03:50 02/05/17) I'm looking at a Case 990. i don't know when the last time it was ran and neither does the owner of it. its got the remotes and power steering and all still hooked up the wiring lookes good everywhere. But I'm at it to get running and use it for food plots and bush hogging and stuff like that. Any advice is much appreciated.
See if it turns over or will start. That's step 1. Otherwise it's worth whatever the tires on it and the scrap price is. The DB990 is a fine tractor, but like anything else, buying an unknown lowers it's value drastically.
