1370 case power steering
lmgraves
New User
I repaired a leaking fitting on my 1370 case power steering line on one of the cylinder, I have bleed both the lines on both cylinder one at a time over and over, but the steering is still very hard, where as before you could turn the steering wheel with one hand, any suggestions.
The system will bleed its self by just turning the wheel lock to lock several times. By just repairing a leak on a fitting really should not affect steering effort at
all. Maybe something came loose at the fitting and circulated up into the steering hand pump, just a wild guess. Start eliminating things by jacking front tires off the
ground and moving wheels and cylinders by hand to see if you can locate any tightness at that end. Rod.
