Firewood Question
popper50
How much wood is on the spreader? its 12'x5x 2' heaped 2' above side, whats it worth in your area
Well when you do the math, from your measurements It comes to 120 cuft. struck load. The back is not stacked square and none of the wood in the box is stacked so my guess is that if all stacked it might end up being a full cord-128 cuft., no more!!! I don't know the going price per cord here in central NY. I cut all my own wood, and buy none.
Loren
Here is a pic of one of my truck loads. When stacked properly it was a bit over a face cord, which is 42.56 cu.ft. This load stacked out at about 60cu.ft.
Loren
Makes a difference what kind of wood. Do you run the apron chain to unload? Looks like the pieces would catch if it piles up.
Looks like Ash to me........ I can see the Emerald Ash Borer tracks all over where the bark has fallen off........ around my place (central Ohio) a cord runs about $60.00
Well after you split it up and stack/rank it, you can measure it, and you will know. I have loaded enough of my trailers to know about how many cu.ft. of wood is on them. This load is a bit over a full cord 128cu.Ft.
Loren
