case 2090 oil leak
kenney970
Hello, I have been reading your valuable tips and advice for several years and now I have a question. My 2090 powershift is leaking hydraulic oil around range shift and park lock shafts. Is this something I can do with a little patience.I have a case shop manual. THanks
I guess you will have to read the manual and decide for yourself. I have no idea of your skill level and what you have for tools and facilities. If you have a shop, tools and mechanical abilities, GO for it!!
Loren
Yes there is a oring on those shafts that needs to be replaced to stop the leak. The manual does show how to remove the shafts, not a bad job. If the RH rear tire is set in, it helps a lot to get that moved out before you start. Rod.
