1175AgriKing
I replaced all injectors, seals, and return lines tee's. Due to an injector leaking from the head seal. At 44 years no point in replacing one seal. Two return line tees broke off while I removed them. Glad that didn't happen Bush hogging!Dad wasn't in shape to do much repairs his last few years of farming. So water took it toll on the fuel and hydraulics. After replacing these things I had a leak on two lines where the fuel line connects to the injector. I removed it, re cleaned and retightend. I ran that tractor at high rpm's for several minutes each time to recheck for leaks. After installing the hood and putting it to work real time I have 4 leaks at that location. Are these just normal double flared steel lines? Or something special that's Case only?
