Before and After
1370rod
Dash for a 770 Diesel 8 speed open station tractor. Dash and shift console cover were rusty and painted previously. Most gauges were replaced, panels cleaned, primed and
painted. CASE supplied decal kit used.
Did you have these decals on hand? I tried a couple of months ago, our closest Case IH (heavy on the IH) dealer in Herman MN and was told the numbers were no good. They're from my book, and applicable to my serial number. #321-3764 instrument panel, and #321-3856 console. Thanks
That looks really nice Rod. Most of the open station tractors I've seen are faded and decals gone. Should be good for a lot of years.Did you get a snow storm Leon today? We have around 4 inches so far.When you drive that 770 do you find yourself wanting to power shift up or down?
They are used gauges that came from a tractor with a cab. They are nice and clean and bright yet. Rod.
Hmmm, I had that set on hand, will check the part no. in the morn. Sure hope I can get more. Rod.
Hi Darrell, the snow did not start till about 7PM. They said we would get 8-10 in. I think it will be more like 2-4. Quite often when driving the 8 speed tractors I do out of instinct try to shift up. When in the 1470 and turning on the ends I stomp the floor thinking I can touch the correct brake also. Rod.
They sure look Purdy. I wish I could keep my shop as clean as yours. My grinders and cut-off tools spread steel filings all through the shop. Once in the while it gets to the point where I just have to stop, reorganize, and start again. That day is near again!!! HeHe. I have a 5gal bucket nearly full of just metal sweepings off benches and floor. It is too heavy to pick up with the handle. Come spring I will sprinkle the filings on my garden boxes. That should grow high tensile strength vegies next year.
Loren
