New year project/Case Eagle Hitch
CZ
Well, here it is, all welded together and test fitted. Now its time for a coat of primer and Flambeau Red paint
No heat treating, the only things that would have caused color changes were my welding and grinding.
(quoted from post at 09:17:15 01/22/17) No heat treating, the only things that would have caused color changes were my welding and grinding.
This turned out great, thanks for showing your work like this.
I am sure you are aware but the arc on the top link must be the same as arc on lift arms for smooth lift, determined by length of arm, just a thought, I'm sure if you have built this Beauty you know this, Dusty
That looks really professional. Taking those measurements is one thing, but transforming them into that welded up... is skill. Good stuff!
