I've had this tractor about a year. It's sat for about 10 months of that time. I went to operate the rear lift today and it would not move. I don't recall checking the rear lift when I bought it.
This tractor has a 530CK FEL on it. It does not have a rear lift selector switch and I don't think it still has a dump valve on it either.
In their stead are two hydraulic valves. After jacking with one valve, I was able to observe the lift raising up very slowly, but it would never power down. The quadrant lever had no effect.
There does not appear to be a lift latch on this tractor.
The FEL cylinders do leak quite a bit, so I'm pretty certain the reservoir level is quite low. Would lack of oil cause this symptom?
thanks!
thanks!
