Case C engine
GreenEnvy
Here is our Case C or CE? engine that came off our Case Q combine. Been inside since the 50s and used it a few times to run a generator when the power was out. Haven't ran it probably since the 80s.
(quoted from post at 23:56:46 01/21/17)
I would sure like to have that to go with my RE power unit! Looks like a nice outfit with the generator to go with it.
I would call it a CE power unit. Here's a pic of my RE power unit.
Before you try to start it, take the tappet cover off, check that the valves are not stuck. They are prone to sticking if not used. Does not take much work to free them. Then make sure they are lubricated with
engine oil.
