Caseih 2096 dies when I push in clutch
Todd D
Tractor starts fine but when I push in the clutch she dies.
I need this fixed. Love this cummins and the power shift.
Todd
If the temp. Is very cold let it run a while, our 1896 does that too. But there could be other issues also as ours has done it occasionally in the summer also
Had a 2290 that did the same thing. Turned out to be the C1 spool sticking in the P/S valve body. It will do a lot of damage if not Fixed. Dennis
we can assume it is a sticking valve in shift body,right side on trans behind cover,4 shift solenoids,ck wires first,then ck.press switchs see if any appear to be broke,start tractor and have someone shift power shift ck.to see if solenoids magnetize at different shifts,(easy stuff first)
I'll do that case trader. Can u send me your email or send me a message so I can ask you some extra questions.
