Case 885 David Brown wanting front end loader
skuchin
New User
I have a case 885 David Brown, I am wanting to put a loader on it, will the internal hydraulics support a loader and if so where would I tap into them? Thanks Steve
(quoted from post at 17:20:45 01/16/17) You would use a power beyond block on top of the remote valve.
Best choice.
2nd would be to use the remotes, either as a power source(that you plumb to the loader valve), or as the actual loader valves(not ideal, but will work if you have 2 spools).
3rd would be to use the "select" function on your 3 point hitch and tap into the front of the rockshaft cylinder for power(factory set ups were mostly done this way).
Would the "power beyond block" be the two ports behind the hydraulic control for the 3 point hitch?
