ust replaced powershift and transmission on the970.. have a gew issues now . three point would not raise . changed thevalve and worked in the shop.. now works intermittenly .. major problem is presure. havent pug a gauge on yet but. gauge on dash is just below the green at idle . rev rpms upand will go into green and remote valves work . also if in reverse or 3.. have good pressure. 1 and 2 it drops. step one inching pedel and can hear motor labor just a second like it should.. and pressure come right up.... i am really hopeing problem is in the power shift valve ... anyone have any thoughts as whats going on with it . did have the power shift out and apart couple bellville washers were bad but otherwise all was good . thanks in advance for any ideas
