4435
Have you had an opportunity to check the spring tension on the 70 series relief valve yet. I have a drawing ready to send. thanks Tom
I can't find the valves that I put "someplace safe". I have a couple cans that I pulled out of a parts tractor that I will try to get apart and measured tomorrow.
So no sooner than I put the socket on the bottom of the can, and look up, there are the 2 valves(that I put someplace safe) on a shelf at eye level in front of the vise...
Anyway, all 3 start to move between 10.5 and 11 pounds force.
The bottom of seal washer is even with the most distant part of the 3/8 holes at between 20 and 21 pounds.
