Been Gone Awhile
Adirondack case guy
My wifey bought a new printer scanner for my compuker. She couldn't get the two of them to communicate.
had to take both to a computer guru and he had to delete my old vista system, and load on Windows 7. It is too old for W10.
Anyway I have been building a nose guard for the 831C. I have the base mtg. frame made from 6" channel iron. It wraps back to where the engine bolts up, and has an enclosed pocket in the front with a 1" draw pin thru it to hook a chain and also I can slide in a custom front hitch and pin it in place. Still need to fab up the square tubing hoop to protect the nose cone and grill. The hoop will bolt to the base mtg. and to the cultivator frame in the nose of the tractor. Also need to drill the 1" hole in the sheet metal cover and tap the holes in the frame to hold it on.
Glad to get back onto YT. Got 4 days of catching up to do.
Loren
You sure do nice work and have great talents. Thanks for the pictures, I look forward to your pictures. Paul
Loren,
I've said it before and I'll mention it again. Your fabrication skills are incredible. Wish I had some talent like that. Don
