Case 210B Starter
Stephen Newell
I need to find someone to overhaul the starter on my 210B and there is no tag on it with an identifying number. On the neck of it in the cast is the number PS1258. I don't know if that is the model number or not. Sometime before I bought the tractor it was converted to a 12V negative ground system. Anyway I need the model number of the starter to find someone to work on it.
Do you have any more information on the starter? The one I have has gotten so weak the tractor can't be started if the weather is below 50 degrees. It just won't turn the engine fast enough to start.
Mine has a 6 volt originally, but all that with the exception of the starter is in a box on a shelf. I switched to 12 volt about 17 years ago
