Happy New Year everyone, they seem to come faster every year! Well the mock-up work is done, now its time to take it all apart and head to the Fab. shop. First picture shows the overall set-up. The top link hitch assemble will be 2 pieces of 5" channel welded back to back. Everything will be welded into a single fixture. The placement of the pivot pin gives me an 18" mast height (per Category 1 standards). The second and third photo are a close up of the bracket and lastly the seat in place.
This whole project started with, "What can I come up with for hydraulics" While doing some research on this I ran into the fourth and fifth pictures. Both show a model S with a hydraulic pump mounted between the governor and magneto. John Saeli identified this as the pump used on the SP-9 and SP-12 combines. More searching lead me to a gentleman who had one from his Dad's SP-12 combine. When the combine gave out he transferred the pump to his model D tractor. Eventually he passed the tractor on, but kept the pump, which lucky for me, he was willing to sell it. The last photo shows the pump, manuals I acquired and a Cross 2 spool valve which has a "float position" on one spool. I plan to use a small torpedo shaped compressor air tank as the reservoir and a Paul hydraulic fluid filter. I haven't decided if I will "hose" everything or go to the added work of hard piping.
One of my criteria was not to modify the tractor in any way. Now it can easily be returned to original condition, if desired, by a future owner. Anyway its back to my regular job tomorrow, so it may take awhile before I can get the rest done. Hope you enjoyed the project, I did, I welcome all coments.
