DC sleeve shims
DKase
Does anyone know where to get shims for the DC sleeves? Mine have very little protrusion, and I noticed the O-rings were tore up as if the sleeves were vibrating in the block. Would like to snug them up a bit if possible.
(quoted from post at 21:10:10 12/29/16) Does anyone know where to get shims for the DC sleeves? Mine have very little protrusion, and I noticed the O-rings were tore up as if the sleeves were vibrating in the block. Would like to snug them up a bit if possible.
I see you been here awhile so I wont ask what the protrusion is but just assume its under .001-.003 or below the surface, and just guessing you need shims because the other alternative is milling the block and sleeve holes to tolerance. Now the bad news I don't know of anyone who sells them heard there may be some diesels that used them hopefully someone will know and help . Knowing the year model & diameter of the I would presume New sleeves your Installing would help. My guess the o-rings got tore up removing or installing them could have been a PO. Best of luck with it Byron
