kub6040
I would like to talk with someone that has and knows a little about a 1030 ,I am wanting to purchase but scared of the unknown. I anyone has time my number is 318-542-0896. Thanks Jimmy.
Jimmy, nice chatting with you. Sounds like the 1030 would work for you. If the PTO is a problem the guys on here will walk you through the repairs and we have people here that can supply the parts you may need..
Loren.
Thanks so much for the call Adirondack case guy , really appreciate your time and patience , I needed reassuring . There are pictures of it listed on central Louisiana craigslist under farm and garden . It has 23.1-30 rears and inside and outside rear weights along with front frame weights . Just need to find it a set of grill screens.
When you are looking for grill screens only ones from a 1030 will fit. They are not the same as the 7/8/930 screens.
Looks like a buy does it have 3pt on back? I have screens in NY and I ship. Looks nice and level with those 23.1's. 6076423293
You could make 730/830/930 screens fit if you use the tin sides from the radiator as well. Just has extra hole for front mount implements
Will that side tin fit on the 1030 nose? I'm not sure on that, but I think they are different so those side tins don't fit right. Could probly be modified easy enough tho. I know the 1030 top piece is different.
