1200 TRACTION KING AXLE SEALS
I AM RESTORING A 1200 CASE TRACTION KING. I NEED THE SEALS FOR THE FRONT AND REAR AXLES. THEY ARE NO LONGER AVAILABLE THROUGH CASE. DOES ANYONE KNOW WHERE I COULD LOCATE THEM. I HAVE TRIED TO LOCATE THEM USING THE CASE LOCATER SYSTEM BUT IT DOES NOT SHOW ANY. (ROCKWELL AXLES)
I have had good luck going to a where they sell bearings and races.take the old seal with you they can match them up.
I HAVE NOT TRIED THAT YET. THE MAIN SEAL ON THE PIVOT BALL IS VERY UNUSUAL. IT IS SOLID RUBBER SITTING IN THE PIVOT HOUSING WITH NO METAL ATTACHED TO THE SEAL. I WILL TRY THAT IF I CAN NOT FIND ONE. THANKS
Do you have the case part numbers? If you have them you can find the modern seal that replaces it by going to this site and entering the case part number. www2.chicago-rawhide.com/popup_parts_lookup_457012.htm Hope this helps Dennis
