Polarizing a Case DC generator
Mathias NY
I just changed out generators on my DC and forgot how to polarize it. It's a 6v AutoLite generator with negative ground and one terminal on the regulator.
Thanks for the help!
Take the fuse out and bump the contacts shut. Probably have to pull them apart, not running they stick and if you leave the fuse in it will blow. I do it with it running and the fuse in.
