Keiren
New User
Hi,
New to the forum and have a question about narrowing down the year of this tractor I want to return to its former glory. It is a case 530 series, gas, adjustable wide front, triple range, with eagle hitch. Which I believe makes it a 541. Can't wait to get working on it. Seems solid and complete. I know it needs a new head gasket.
Can only locate engine serial number at this point. Last run more than 5 years ago. Thanks in advance for any insight and help.
Thanks, I'll have to look again. on the right side by engine is a plate with # 2007514 I believe. I kind of like the clam shell fenders better and probably keep them if they clean up good. Cheers,
nice tractor! i'm starting to see that maybe the correct fenders are the way to go. that has a nice look
thanks to all for the great info.
I have yet to get behind the wheel of one of these. I don't believe mine has power steering or assist. do they take some wrestling to turn?
There are some old good years on it for tires. would firestones be the way to go? I don't plan on doing a lot of field work with it, mainly just utility tractor work - maybe someday see about putting a small loader on it if possible.
It may be spring before i can work on it, but every time I see it back in the shed it makes it harder to wait
