Adirondack case guy
Haven't spent much time in the shop lately until today.
Had to fab up a lifting gig that bolted to my cherry picker to mount the Rops structure onto the tractor. Made that up and test fitted the two post strut to the tractor. I need to relieve the notches in the channel iron bases a bit so they slide down over the axle housings and clamp tight with 8 3/4x8" bolts and bottom clamp brackets. I made the clearance tight, figuring that I could releive them to make a perfect fit.
I will have about 11" of head clearance when seated on the tractor. Currently in the pic., the fenders are just setting against the tires. The fenders and canopy will all be bolted to the ROPS struts and they will become one consolidated unit.like a 70 series cab. I will stash the lifting gig away incase the structure needs to be removed in the future.
Loren
Loren
