Replacing Starter on Case 495
We're replacing a starter on a Case 495 and it looks like we need to remove the fuel filter in order to do this. Will we need to bleed the fuel lines if we take off the fuel filter? Any help or advice would be appreciated.
Before you take the fuel filter off, be sure the fuel tank is half to right full of fuel . This way fuel will flow down to the filter, and be sure the filter is full of fuel when it is put on . The tractor will most likely not need to be bled.
