I have a neighbor that needs help with a 2003 7.3L Ford Diesel engine and I am asking this board because you guys seem to be the most willing to help.
The truck was driven into their lot shut off and now refuses to start. It doesn't seems to get fuel.
They changed filters replaced the fuel pump and cam position sensor at the direction of a diesel mechanic ALL with no results. Engine still will not start.
The same mechanic put a code reader on the truck and claims now there is a wire bad on an injector under the valve cover. Needless to say the owners aren't ready to spend any more money until they get more information. The mechanic already cost them several hundred dollars for apparently needless repairs.
The only thing they have noticed is they seem to now have a short in the truck, because the battery drains from a load.
O know this the Case board but if any of you have any ideas please chime in.
Thank You brokengun
Thank You brokengun
