Paul Shuler
RG and Bob. I drained all of that brake fluid out and removed the master and slave cylinder. When I opened them up oh my word. Looked like they were full of rust colored mud. I can?t believe that they ever worked. They must have been in bad shape a long time. The brake system seems to be working great but just to be safe I am going to pick up some of the mineral oil and thoroughly flush out the brake lines and reservoir and replace with new clean fluid that I know for sure is the correct thing for nothing else for peace of mind. I have parts on order for the clutch cylinders and I think it will be above freezing here in MO so I will try and flush the brakes then. This tractor is a little too large to fit into my nice warm shop so it?s out on the cold ground I work on this one. Thank you guys for all of your help. Will try and keep you up dated.
