vac hydrolics
handcrank
started my 1950 vac today and for the first time ever,the lever that raises and lowers the eagle hitch won,t move in either direction.never had this happen before.I hope someone can tell me what the problemis. Thanks Don.
is it below freezing temps?,,, either way sounds like the control valve spool(s) are stuck to me,, if freezing temps I would say you have moisture in the system
cnt
Well if your temps are like what I have and you have any water in the system then it is froze up. That or you have a very heavy weight oil in it
