joestewart
Gentlemen, I am in need of some advice. I am rebuilding a 1980 David Brown 990 and the block I am using is a solid block (no sleeves). This block came from a tractor that was sitting out in the woods for several years. The motor was filled with water and all four bores were rusted. I had to pound the pistons out. I brought the block to the machinist to have it bored to eliminate the rust pits. The machinist called me and told me that one of the bores has a crack and he will have to install a sleeve. I bought some "straight sleeves" and gave them to him, but he is confused about what to do about that "sealing ring" at the top of the bore. For those of you unfamiliar David Brown blocks in this model, there is a steel ring at the top of each bore. The ring projects a few thousandths of an inch above the deck surface to aid in sealing the combustion chamber.
Question: When you install a sleeve into a motor of this type, what do you do with the sealing ring? Is a "straight sleeve" appropriate for this set up? Or is there a different style sleeve I should be using?
Thank you in advance for your input.
