Case 2290 specs
cjrpr
Hi. I ordered a shop manual for a Case 2290. It hasn't arrived yet and I'd like to get this tractor put back together now. Could someone please help me out with telling me what the main and rod bearings and the cylinder heads get torqued at? Also the valve lash settings. Thank you in advance for any help. It's a early case 2290.
rod caps 95-105 ft lbs mains 200-210 ft lbs cylinder heads 210 ft lbs tighten in three stages 70 140 and 210. case bearings sometimes have holes in one shell so be careful to put the shells in the right spots .my old boss said he didnt do it once and wrecked a crank . intake valves .015 exhaust valves .025 inch warm most engines have some specs. on one of the valve covers
