CASE SC HYD. OIL
Allen L
My service manual is a little hard to read. Does the SC take SAE 30 engine oil? Is it added to the same fitting as the transmission oil as they seem to be right next to each other. thanks in advance for any response. Allen
hydro is the rearward smaller plug ,hydro housing has a 1/4 pip[e plug located on most on rite side of housing ( location varies )to indicate full ,. I use 10 wt oil ,. but have added 30 wt ,.. either should work fine
