1030 CK seat
The seat on my 1030 Ck rocks real bad forward and backward; this just started recently. What has most likely happened? The torsion rubber come loose? Or?
It is not living up to its name "Comfort King" :)
Thanks for any and all help!
Common issue on those seat suspensions. Back and forth indicate worn rods and holes. You can try drilling the holes round again and putting bushings in or welding heavy washers on frames. Seen both done. Up to you
Had the same problem. Cut off old holes and welded on pieces of steel with new holes. It really worked good and you can hardly tell what was done just by looking.
Thanks
