Finally removed the power shift valve, Need to be able to stand on your head and add another joint to the arm to get at some of the fixtures under the platform, BUT, did not have to cut the platform up to get it out...C-2 was stuck as Rod suspected in earlier post, other valves were sticky. I saw it was mentioned to get the correct gasket set, If I have my local Case-IH parts gal look up the number from my parts book should get the correct one? How will I know if they get me the wrong one? Anything else I should be doing, long as I have the valve off? Thanks for all of the advice and pointers from everyone, Greg
