pilotou
New User
Hello all, Ive posted here before and got tremendous support. I recently purchased a Case 1175 tractor with cab. It had been sitting in a field for 3 years and was left unattended. I was able to get it running so I started changing the oil and getting it cleaned up. But my problem is, is that rats or squirrels chewed through the wiring and I was trying to see if anyone had the wiring schematic for the cab. Especially the heat and air controls. There are a few wires chewed through on the panel but I think that I can figure that out. If anyone has this, would you be able to help?
Thank you in advance
Here's the wiring diagram from my 1090/1170 service manual, probably be similar to your 1175. I resized the scans to post on here, if it's too small I'll try again with a bit larger format.
