Gary Singleton
I just took my pump off to try to time it, and all the instructions I am getting says line up 2 marks on pump shaft and get number one(1) cylinder tdc, look above starter and line up 8 degrees and all is well --well my pump only has 1 line to line up unless im doing something wrong, I turned it with a large screw driver? then im told the flywheel marks are in a trap door above the starter well mine doesn't have a door or slot or anything where I can see flywheel so does anyone know whats what, the model on my valve cover says its a G188D and times at 4(four )degrees I know its a little old but it ran great and I broke the throttle and cut off shaft on throttle side had it replaced so now cant start it thanks for any help and thanks al for your advice
