I have a 1962 Case 930 Diesel,6 speed (not a CK), wide front. Barn kept. Owned and used it from 2004 to 2012 to pull disk and planter. Always needed a shot or two of ether to start. Hasn't started in a while. Injectors are probably plugged up from dirty tank. Replaced all three fuel filters, bled lines, still wont start. Noticed oil in the water (even back when it was running) so it most likely needs a valve job, new oil seals and head gaskets. Could use one back tire, and front tires are dry/cracked. Generator doesn't work. Needs work on platform where previous owner retrofitted a home made 3-point that didn't work out. Does have a PTO with new seal. Needs a clean up and paint.
I have a potental buyer but I want to be fair with the price. Any ideas based on my info above?
Thanks
Thanks
